You can set per-color, or global defaults for the cut settings in the Cut Settings Edit window. You can tell LightBurn to reset to those when you make a new file (in the settings, file settings pane).
Having the system warn you that you don’t have kerf enabled would be pretty specialized. Most users would want that the opposite, I suspect (IE, you have kerf or some other, less used option, enabled - are you sure?)
