Fiber laser is unresponsive to power input changes after minor update
Hello, my 30w Raycus fiber laser is not responding to power changes after the latest update, the issues only appears to be with images when engraving text it is OK, I am trying to engrave some steel dog tags and it doesn’t matter if the power is at 50% or 1% it still outputs excessive power which can be seen by the sparks flying off the tag. (which is destroying the quality of the photos by burning and digging too deep) usually I run the photos at 30% power and 100 mm/sec, i switched to 1% power just to experiment if it was the power and not the focus and the 1% power also burned the tags
Usually when doing a photo pass the sparks are very small and almost silent, nothing has changed since yesterdays batch the only variable that has changed is the minor update, I tried to uninstall and re install the previous version however the issue is still present.
Any help would be greatly appreciated, thank you
