Fiber laser lens issues
Hi to all, I am hoping someone can help with this problem, I have a Monport 50w fiber laser and a monport reno65 pro vision, The problem i have is with the fiber laser, i have 3 lenses, 70mm, 150mm and 200mm. all lenses are calibrated and work fine,When they load !. The problem is when you select the lens you want to use from the drop down it doesnt always load you have to keep switching between the different lens and eventually the lens will load and the boundary box will show up. I take my fiber laser to shows with me and it gets very frustrating when the lens doesnt load straight away. any help on this would be greatly appreciated.
I have no swappable lenses for my lasers, but if lens change is buggy, I’d suggest adding the device three times to LB, each containing the settings for the individual lens and then just changing the device when changing the lens.
Thats what i have done, all 3 lenses are in lightburn, The problem is when selecting the disired lens from the dropdown menu it doesnt always reconise the lens i have selected and i have to keep on selecting a diffrent lens until it does finally loads, For example, I select the 70mm and that will load fine and i can use it but then when i switch over to the 150mm it doesnt work.No red border box, so i randomly keep switching between lens and evenually it will work
When you configure a fiber galvo for Lightburn, it asks for the ‘EZCad config’ file. This file contains the information to configure the control board with whatever source you have. If the lens came with the machine, there is also lens correction information with this file.
If the lens is an add on, you have to make a cor(rection) file for it. Then when you create a new device, you load the EZCad config, then you must open the Device settings → Galvo and basic settings. There you can load the cor or lens configuration file.
This makes the association between lens and it’s setup and correction files.
Make sense?
:grinning_cat:
All the lenses are added in lightburn and work fine,Its very hard to explain so i I have created a video now on youtube,Hope this helps sort my problem https://youtu.be/jGA1n9lD_Mc
You need to look at how the device is setup. Might want to take a screenshot of the first group that tells it how to deal with the controller.
I didn’t see you create these devices, so It’s difficult to tell if you missed something or not.
Usually, you don’t fix them by repetitive loading of different lenses. Check these two panels in the device manager for each lens and see if they are the same, other than the cor file. Which lens came with the machine?
:grinning_cat:
You changed the settings but didn’t change the lens. It looks like the lenses have a very different field of view. I guess if you’d change the lens, you would see the frame as well. The angle is very different.
I had to make different machine profiles for each lens.
The Laser On/Off/End/Polygon TC are about the only things that need to be set across profiles. Those params are tied to the BJJCZ controller, galvo head, and MOPA source.
All the scale/bulge/skew/trapezoid cal and work field size are specific to the lens.
And what many don’t see is the max speed changes with the lens, too. Because the limitation is galvo mirror’s angular speed and more specifically angular acceleration. The resulting linear speed scales with the focal length.
When you change machine profiles, it picks up a different library. This is best. The spot size. thus the power intensity, and speeds are all very different when you change lenses and settings don’t really translate.
It’s annoying when you prepare a job under one lens and load under another profile and it warns you and offers to change profiles. LB probably has the best implementation already. It can’t jump in and change your layer settings for you, but all the job work one in the workspace is preserved
Unless I don’t understand this statement, which is always possible, I don’t believe this is correct.
If I ask for 500mm/s with a 100mm sq coverage lens, then switch to a 200mm coverage, it doesn’t run 1000mm/s of a sudden by a lens change.
With any lens, the mirrors will still have to travel it’s full distance, regardless of it’s focal length to do the entire coverage area for each lens.
Lightburn knows the lens you have and adjustments are mode to reflect surface speed, which is what people understand.
:grinning_cat:
Both the F163 and F420 lens occupy the same angular mirror sweep, I read it’s +/-11deg.
Say you determine a 3100 mm/sec linea speed on an F163 110x110mm field is the sweet spot where accel is not significantly interfering with tracking. That’s 19 rad/sec speed on the mirrors.
Put an F420 on it (300x300mm) and 19 rad/sec makes 8000mm/sec
It will take the same amount of time to sweep across the entire field width. True. But what’s the relevance of that, comparing cut times of a 110mmx20mm job with a 300mmx20mm job and seeing they take the same time per pass?
The number you’d want to compare is like a fixed 25mm dia coin. The F420 linear speed vs F163 is a 2.58x gain for the same galvo head.
The longer lens is a larger spot size, which I’ve come to see is not necessarily worse. It can still produce finer detail than you can see with the naked eye, and you can generally scale up LI which directly speeds up runtime again. The largest 500ns pulse works great.
When going with max pulse energy, smaller spots may actually create quality problems due to excessively high energy density.
I’ll have to percolate on this for a while. Thanks for the reply…
:grinning_cat:
I can get a high quality 25mm brass 3d relief coin in under 10 min
