File Data Error, IDK Why
My Boss HP 3655 is not correctly sending files to the laser. I used it a month ago with no issue. It can still run old files, I cannot send new files. Not even a simple box drawn in lightburn. I really have no clue what to do. I have updated lightburn to the most recent version and reset everything several times. Any help would be appreciated.
Did you check if the memory is full at the controller.
Possibly delete an old - not used - file and try sending agian?
I think that was it, thanks!
Worth regular checking as DSP controllers can have issues that manifest in unexpected ways and not consistently. In general, checking the storage to ensure it has room for incoming files is a good item to add to your regular machine maintenance. :slight_smile:
