Is there anyway to change the default when opening files to all file formats supported instead of just LB. Every new file I open in LB is a PDF before I make my modifications and save in LB format.
Why yes that does work. Thank You.
“Open” is for project files, and replaces the current content of your project with whatever is being loaded.
“Import” is for vector or bitmap graphics, and imports them into your current project.
Each mode sets the default file types according to the expected way they’re used. If you want to clear the current project and import a new graphic into a blank workspace, Ctrl+N (New) then Ctrl+I (Import) is fastest.
