File List can't add file
Please help. I use the File List to copy files I design that I then take to the laser to engrave/cut/etc. However, I can no longer add files as the file list button used to add the file now just shows a greyed out (inactive button) clock and text :two_o_clock:Calc Time. Everything was file until today. Has something changed? Is there some setting somewhere I need to change? I looked at the current documentation about the file list and it also shows the Calc Time text but nowhere could I find any info in adding a file to my RDFile drive using the list. My design department is in a different location so the only way I can communicate with the laser is via the RDFile thumb drive. Thanks in advance for any help you can provide.
Please disregard this issue as I have been working way to hard.:laughing: I wasn’t looking in the correct window. I should have been looking at the laser window instead of the file list window.
