do I remove the whole folder?
Yes, this is what i did but first i exported it just as a backup. you can also just rename it to like .zzzz or whatever and check.
I have removed the whole thing. I icon is still the same and with double click still open the file. no preview, I am missing something
I believed you, I just have no idea what that would be, or how to fix it. There is nothing special about the handling of text objects compared to others for the purpose of generating the preview.
Iknow, thanks for trying. I really wanted it to work.
You have to save files with the latest release (or at least the 0.9.09 release) for the previews to show up. Have you done that as well?
I am using the latest update. I made a new project and saved it. delete the registry, still no preview.
Yes, this is a great LB feature but unfortunately windows is unpredictable and so this works on some systems and not on others.
I also have no previews. Win 10 ver 1909 latest update.
I figure something by accident. in my laser folder I did search for just Lbrn (*.lbrn) and then lot of my project showed preview, not all, which is soooo helpful. So this may work for others.
If I close the search the preview also goes away - interestingâŚ
please see picture.
Hope this also help LB programers in figuring this out.
I hope I made someones day
It will only display previews on files saved with a recent version (0.9.08 and up, I believe - whenever previews were introduced)
Yep, it was the 9.08 release.
- Explorer thumbnails for Windows version (doesnât work yet on all systems - still investigating)
Still not working for me
0.9.10
Windows 10 Home
Build 18362.720
Vesion 1903
Have you ever created a file association to launch LightBurn when double-clicking LightBurn files? It seems like the most common cause for failure of the thumbnails is that - If you manually create an association, instead of letting LightBurn do it, it overrides the stuff I set up.
