I’m getting file transfer failed on all jobs over 80kb
eg. displays file transfer sending 727kb and will randomly stop anywhere form 10% through to 80%
sometimes I can try sending the job 20 -30 times and it may eventually succeed
small jobs under 50kb very rarely fail
running LB 1.2.04 with a ruida 6445g controller on a wired Ethernet cable
When this occurs I delete all files from the Ruida memory. It has a hard time with large files and memory management…
Are these grayscale files? They take a lot of memory.
Ethernet is the best interface, so you should be good there…
Good luck
Tried deleting all files, didn’t make any difference
it was a engraving job all text total size 350mm wide x 500mm high
no grey scale or pics
