I upgraded my software to DSP and now all my files open upside down. Is there a fix for this?
All files saved in LightBurn use the machine origin as a reference point. If you open the file on a machine profile with a different machine origin, they will be flipped around, so it’s working as designed unfortunately. That’s the one pain of working with multiple machines with different origins.
The design changes because the origin determines which quadrant in which the machine operates.
It’s ‘flipped’ across the perpendicular axes between the two quadrants.
Select ‘all’ the objects then use the mirroring icons to correct it…
