Fill function or fill offset not visible
due to the premature death of the HD, I had to reinstall the lightburn of December 2022, not having the right to updates; everything seems to be going well but now when I import an old project or set a new one, if I select the “fill” (even offset) instead of the line, on a visual level Lightburn no longer makes me understand that that stretch needs to be filled and only shows me the lines. - It’s just a display problem but I wouldn’t mind going back to when I actually saw those fields filled in and not just represented by lines.
Try “Filled Rendering” under “Settings”, if I understand your question correctly.
yes, so little was enough and I didn’t know anything about it; thanks so much for the help :clap: :clap:
