Hi LB
I spent quite a few hours trying to figure out why this happens:
- When “Fill + Line” some text as-is, LB would first Scan and then Cut.
- When you take that same text and “Convert to Path”, LB would first Scan and then Cut.
- If you then Group the text , LB would first Cut and then Scan.
Scan is set to “Scan all at once”
This caused a huge problem because in scenario no 3, LB did not use the “Fill + Line” settings for the “Line” part, but some other (unknown) settings that caused the Line to burn right through.
