after the last update realized files do not behave as before, for example when I select “Line” on red color for example everything is ok, but if I select “FILL” nothing happens, the interior space does not fill with color remains still at the stage of “Line”
The view in LightBurn is not filled by default - we don’t recommend working in filled mode all the time because it hides things, it’s slower, and it can be more difficult to select and edit shapes. The preview will always be the best reference for checking your output.
That said, in the Window menu you can turn filled rendering on & off.
