I’m new to LightBurn so if I am asking a question already asked and answered my apologies. But I’ve tried googling the issue without luck.
Here is the problem:
I import an image file into Lightburn (JPG file).
I trace that image and then select the trace layer
I set the option to only burn selected graphic
I set the cut to line+fill, laser (5W) to 50% power and 200 mm/s
The preview looks fine, the fill is shown there in black (i.e. to be burned).
But when I start the burn the laser moves over the fill areas but it doesn’t fire the diode so fill areas don’t get burned. Lines are burned without a problem.
Hi,
I tried using 50 mm/s but same result, laser gets moved to the fill area and looks like it is “filling” but it doesn’t fire the laser.
I looked at the device settings and I don’t see an option there to turn on Laser mode (I’m running version 1.0.0).
I’ll try setting $32=1 tomorrow as I’ve already shut down the shop for the day (I’m in Europe).
Oz,
I’m using GRBL-M3 version 1.1e or earlier (or at least that’s what the device settings tell me).
I did do a quick trip to the shop and try the $32=1 option but, unfortunately, still the same situation.
