When light burns sends out its commands to burn a closed Vector object using the filled command does the burn consist of something like a dither pattern or is it a continuous burn?
A fill is a continuous on state at the specified speed/power while within the fill area.
Simpler than that! It’s just a raster scan at the set power over the entire object:
The illustration in the doc shows the scan:
What’s not shown are the overscan regions on either side with the laser beam turned off and the laser head accelerating to the set speed and decelerating to a stop before reversing:
As shown by the red regions of the Preview
Which is why you must keep the engraved region away from the sides of the machine platform and always preview before Firing The Laser.
