keep getting vertical lines through text areas and on the inside of images, created this test inside lightburn. pictures of what was burned and the layer settings in lightburn i used.
using a Ortur Laser master 2. just stared hapening a couple days ago, im new to this program and using a laser, any help with settings or solutions to what i did to make this happen would be appreciated
laser mode is enabled. checked the $32 and $30 values both are correct and match the S value max. Is there an option to do a factory reset for LightScribe ? just to check i didnt mess up soe random setting ?
