Final Camera image has curved sides
I’ve got an original Bolt by Thunder. The. Original camera settings they sent with the laser no longer work in LightBurn with the new updates. I went through the camera setup process. I printed and used the glyphs. Put them in all 5 positions. My final image I get with the camera, the edges are all bowed outwards and they’re completely useless. I’m not sure what I’m doing incorrectly. I don’t think this is a complex process. But I see many others having issues getting their cameras to work also. I’ve tried multiple options through the camera setup, choosing the Thunder camera, choosing just to start from scratch and nothing works. If somebody has a process to actually get the camera to work on original Thunder Bolt, I’d appreciate some direction. Thank you.
I was having this issue with the Roly Lasermatic. After multiple trys I imported the factory lens calibration first then used the LB aligning. That worked for me . Good luck.
When I import the factory setup file, the image that I end up with looks like the Four Corners are attached to the surface but everything else is stretched way way far away. I’ve tried zooming in and playing with all the settings and the most I’ve got it to recognize was one of the eight glyphs.
