Hola buenas me podéis decir cómo conectar los finales de carrera en esta placa gracias
(Hello, can you tell me how to connect the limit switches on this board, thanks)
Is this a sculpfun board? The only thing I could find on-line was reference to the MKS DLC32v2 board, which has the limit switch connections around here I think:
Link to the MKS docs here
I’m not certain it is the same on your board as I can’t see the marking next to the pins I’ve circled.
A full guide with all pictures is here: Limit Switches - Diode Laser Wiki
