Finally, Consistent Titanium Dioxide Results
I finally have consistent, repeatable results using TO2.
Mixed by weight at 15% TO2 to Dollarama white acrylic paint. Once mixed, I add enough water to make it flow easily to keep lines to a minimum because I put the paint on with a 4 foam brush. These were both done on a 5.5 Watt diode because I wanted to check it out, but I get great results (and faster) using the CO2.
As far as I have been able to tell, adding the water after to make it flow better does not cause issues.
The tiles are from two different big box stores and they were made using two different batches of paint/TO2 solution just to make sure the results were not a fluke.
Now the only smelly things in the laser room are my socks - maybe it’s time I use some water on them.
I love it when a plan comes together! Great images.
