Finding Grbl control
Hi
After running about like a headless chicken worrying about port settings on my Linux laptop I finally got Lightburn set up and the Ortur laser moving around. There was one error message I got that I’m not sure about and that is
Homing cycle is not enabled in your Grbl settings.
Not sure where to set this, come to that I don’t know where the control is for Grbl on Lightburn.
Perhaps some one could point it out please.
Thanks a lot.
Fabian.
This means you modified your grbl $22=0 probably
Lightburn tries to home on start up of connection
You can $RST=* in console to get your ortur back to defaults
Hi
As a beginner using Lightburn I don’t know how to “You can $RST=* in console” although I’m grateful for your help.
Fabian.
go to window → console
A new pannel will apear
Once you are connceted in the console pannel there is a box that says “type command here”
inpht there
$RST=*
press enter
Machine should respond with MSG: Restorign defaults
Thanks, Gil
Just as you described, worked a treat.
Thanks again.
Fabian.
Great news!
