Finish one design before moving to the next when using a grid
Hello. I am using lightburn and have a longer ray5 20w laser.
I use the grid pattern a lot to make 25 identical items consisting of a design and wording.
My question is is there a way to make the laser finish the wording completely before going to the next. Currently the laser just goes from one end of my work space to the other increasing in work time and well as an inconsistency in the burn.
Please see:
If one of your layers is set to fill or offset fill doubble click on the layer and try the 3 options down the bottom, each time you change it go to preview and turn on traversal moves and also check estimated run time to get best result. Avoid offset fill on anything except simple designs, it will bog your processing down compared to just Fill.
