Fire button option during position or location button
Good morning guys,
I am hoping you can incorporate this into update. We have a location tool in lightburn. When we have the fire option it only runs in the frame mode. Can we have a update where the location pin placement also have the option of having a fire added to it.
Reason i am requesting this is manier times the frame button gives a close proximity but it doesn’t allow exact positioning for a part as it has to be eye balled. It would make life very easy if the fire option is available.
Also is there an option to restart on same place if machine has been stopped. You see like a preview option you have a real low power laser to run over the design that way if any instance if the machine shuts off or something else happens you have the capacity to re run over the design to find exact starting point.
Will be greatly appreciated.
Narendra
