Fire button stuck in high power even when framing
Lightburn was working fine. Not sure what happened. Now even when I frame it looks like it is burning on high. What do I need to do to correct this. Running latest update. Using Neje 80W Burned several Burn Grids and it worked fine.
Waiting for connection…
ok
[AUTHOR: RenShen]
[MODEL: Ortur Laser Master 2]
[OLF: 137]
[DATE:01:15:16 - Apr 20 2020]
[VER:1.1f.20170801:]
[OPT:VZD,35,254]
Target buffer size found
ok
Homing
ok
Project loaded in 1405 milliseconds
<Idle|MPos:0.000,0.000,0.000|FS:0,0>
ok
Starting stream
Stream completed in 0:03
ALARM:3
Reset while in motion. Grbl cannot guarantee position. Lost steps are likely. Re-homing is highly recommended.
ok
Ortur Laser Master 2 Ready!
OLF 137.
Grbl 1.1f [’$’ for help]
[MSG:’$H’|’$X’ to unlock]
[MSG:Caution: Unlocked]
ok
<Idle|MPos:313.700,61.550,0.000|FS:0,0|WCO:0.000,0.000,0.000>
ok
Starting stream
Stream completed in 0:07
ALARM:3
ok
OLF 137.
ok
$0=20
$1=50
$2=0
$3=0
$4=0
$5=0
$6=0
$10=1
$11=0.050
$12=0.002
$13=0
$20=1
$21=1
$22=1
$23=7
$24=600.000
$25=3000.000
$26=100
$27=2.000
$30=1000
$31=0
$32=1
$33=250.000
$100=80.000
$101=80.000
$102=80.000
$110=9000.000
$111=9000.000
$112=9000.000
$120=2200.000
$121=1800.000
$122=2500.000
$130=400.000
$131=430.000
$132=1.000
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
[AUTHOR: RenShen]
[OLF: 137]
[OPT:VZD,35,254]
ok
Homing
ok
<Idle|MPos:0.000,0.000,0.000|FS:0,0|WCO:0.000,0.000,0.000>
ok
<Idle|MPos:0.000,0.000,0.000|FS:0,0|Ov:100,100,100>
ok
Starting stream
ALARM:3
ok
OLF 137.
ok
<Idle|MPos:357.000,61.550,0.000|FS:0,0|WCO:0.000,0.000,0.000>
ok
Starting stream
G00 G17 G40 G20 G54
G90
G0X1.9233Y2.4233
M3
G1X14.0767S2.5F235.984
G1Y14.5767
G1X1.9233
G1Y2.4233
M5
G0
G90
Stream completed in 0:06
M5
ALARM:3
ok
OLF 137.
$X
ok
G0
G0
G0
G0
G0
G0
G0
G0
G0
G0
G0
G0
G0
G0
G0
G0
G0
G0
G0
G0
G0
G0
G0
G0
G0
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
$I
[AUTHOR: RenShen]
[OLF: 137]
[OPT:VZD,35,254]
ok
Homing
$H
ok
ok
ok
Starting stream
G00 G17 G40 G20 G54
G90
G0X1.9233Y2.4233
M3
G1Y14.5767
G1X1.9233
G1Y2.4233
M5
G0
G90
M5
ALARM:3
ok
OLF 137.
$X
ok
The S parameter there is 2.5, meaning it’s trying to set 0.25% power. Your laser module or control board is likely dead, or incorrectly wired. I would suggest contacting Ortur Support.
