Can you post the file, or a shot of the extended settings you get when you double-click the black entry in the Cuts / Layers list?
Turn off ‘Dot Mode’. That’s what’s wrong. More generally, if you ever have a layer that doesn’t work the way you think it should, click ‘Reset to Default’ at the bottom left, then apply whatever settings you want.
Should I have enabled cut through mode?..not really sure what that does
In general, if you don’t know what something does you don’t need it.
Cut Through is documented here: https://github.com/LightBurnSoftware/Documentation/blob/master/Operations.md#Line
Thanks Oz…I’ll check that out
Will try right after willie…Thanks again, you guys rock
