So I’m running a Mac using my new ortur laser master 2.
1 I can only get the laser to turn on when I press the play button, I can’t get it to come on to fit and adjust the laser. When I press the frame button it drives the unit around but no laser, so I really have no idea where the burn will start or fit.
2 it constantly tells me I have to reset to continue. alarm 2 - line 4 and 2 .
Pressing Frame by itself does not fire laser. And if the laser is on (via the Fire button) it will turn off. In Windows though, pressing Shift when clicking Frame turns the laser on while doing the frame. Probably should also work for the Mac.
Does it turn on when you press Fire in the Move tab? (Note you have to enable the Fire button in the Device Settings and restart LB). Also make sure the % power for the fire button is high enough. My laser won’t fire unless it’s at least 15%.
