I bought a Ortur laser master 3 No problem assembling it but when it came to firing up, the instructions stated that a TF card needed to be inserted into the computer used then inserted into the laser. Looking at the TF card i didnt relise that it was a usb card with micro card inside. So after i loaded up the TF card on the computer there was only one usb slot for it to fit at the side of the laser where the power cable is inserted near the Wyfi, the instructions said that the TF card needed to be inserted at the back of the front panel near the reset button, obviously the usb TF card dosent fit the slot here, didnt relise or was made clear a micro card taken from the TF usb stick slotted here. So i assumed the TF card went into the usb port at the side loaded up the laser and then replace usb cable to computer. Now i have sorted this and placed the mirco card in the correct slot i proceeded to fire up the laser without connecting it to the computer. When i switched on the key the power button flashes white then to blue where the laser head then manovers to the bottom left side facing the front, when the laser is in position the power light turns green and then every 6 seconds flashes yellow three times then to green.
I downloaded lightburn onto my computer without connecting the laser just put in the details etc and bed size etc tyen conected up to the laser, done it manually suppose. on the right hand top panel on lightburn i clicked to console which showed me a message " waiting for connection" which just stays in this mode, nothing much hapens. Not sure if i have to start again or start again down loading lightburn while i am connected to the computer, the computer i will be using to be cutting using the laser. . Anyone know what the green light is with intermittent yellow flashing light is, cant see what it means in the manual
