First time user: "error:20 Unsupported or invalid g-code command found in block"
I am using a Sculpfun S9 with a very simple design. However, the first layer (etching) fails with error code above. If I switch the order of the layers, cutting works fine. I attached my g-code.
I checked the other error messages in the forum, but they do not seem applicable to me. I have the z-axis disabled (and I see no Z instructions in the g-code).
Any help to get me started would be appreciated.
hans.gc (28.2 KB)
Greetings Hans
Question. by any chance did you enable GCode Cluster in Edit → device settings
if so, please uncheck it
Post please
a) version of LightBurn
b) screenshot of Edit > Device settings page
I have it. I was using wrong type of Air Assist. M7->M8. Should have scrolled further down. Thanks for the suggestions though.
