when I laser images are mirror need help please
Where does your laser go when you first turn the system on, and where do you have the Machine ‘Origin’ set in LightBurn?
I believed when I first setup lightburn i choose top left
They need to be set the same, LightBurn needs to be set to where your system hunts when started or things will produce flipped or mirrored or both.
Thanks Ricky your picture really help…do I have to have “green” on axis x and Y
You are welcome.
Please rephrase. Not following what you are asking.
Mine doesn’t have this sections on green
OK.
Is there a question here?
You can use more words, it is ok to be as wordy as you can be to help us understand what you are after.
