During editing on a project , why does some lines flash, while other do not ?
likely in video , but i must have missed it
DXF file if that is important
Most likely you have lines overlapping or doubled up, and need to delete the duplicate shapes.
Do this as a test to see it:
Now, if you select all (Ctrl+A) one of the circles you see will show the normal dash pattern and the other will flash, because the two circles in one place have their dash patterns moving in the opposite directions. (mirroring a shape will reverse the order of the marching dashes).
