Lightburn finds me Sculpfun S9 correctly. After loading an Ai or Dxf file and starting cutting, the image is flattened. Moreover, the X field set to 180 mm gives the correct settings for the laser position. Why? Where can I find the cause?
Maybe go through these guides to get the settings right: Quick Start & Overview - Diode Laser Wiki There are many sub-guides that should answer all your questions.
