Hey !
I have lightburn connected to an OMTech Polar. In the move tab, it has a distance field to focus the laser, but its greyed out. Something Im missing?
Check to see if you have ‘Continuous Jog’ enabled. The distance field is the movement increment of each click with ‘Continuous Jog’ disabled, so it’s greyed out if it’s enabled.
You can read a bit more about the difference in behavior between the two options, here:
Thank You, I couldnt find that info anywhere
