I’m trying to run a focus test, keep seeing it stop after the first line (frame works ok, preview works ok), and before it starts the legend. I can’t see the gcode in the console, so am a bit in the dark here, but the status report seems to imply the feed rate is set to zero. I don’t think I’ve got it set that way(?), but this could very well be my fault. Jogs ok (without $J enabled, which works fine in UGS, but not in lightburn?), returns to home ok. I’m running without the laser module powered on (module on shapeoko3), just testing movement is what I think it should be. Z movement is enabled.
at origin
Starting stream
<Idle|MPos:-260.409,-320.000,-10.000,0.000,0.000|Bf:11,227|FS:0,200|Pn:AB|Ov:100,100,100|A:CF>
<Idle|MPos:-260.409,-320.000,-10.000,0.000,0.000|Bf:10,240|FS:0,200|Pn:AB>
<Idle|MPos:-260.409,-320.000,-10.000,0.000,0.000|Bf:9,254|FS:0,200|Pn:AB>
<Run|MPos:-260.409,-319.713,-10.000,0.000,0.000|Bf:8,239|FS:3000,200|Pn:AB>
<Run|MPos:-260.409,-319.538,-10.000,0.000,0.000|Bf:8,239|FS:3000,200|Pn:AB>
<Run|MPos:-260.409,-319.314,-10.000,0.000,0.000|Bf:8,239|FS:3000,200|Pn:AB>
<Run|MPos:-260.409,-319.052,-10.000,0.000,0.000|Bf:8,239|FS:3000,200|Pn:AB>
<Run|MPos:-260.409,-318.715,-10.000,0.000,0.000|Bf:7,254|FS:3000,200|Pn:AB>
<Run|MPos:-260.409,-318.390,-10.000,0.000,0.000|Bf:7,254|FS:3000,200|Pn:AB>
<Run|MPos:-260.409,-318.066,-10.000,0.000,0.000|Bf:7,254|FS:3000,200|Pn:AB>
<Run|MPos:-260.409,-317.741,-10.000,0.000,0.000|Bf:7,254|FS:3000,200|Pn:AB>
Stream completed in 0:00
<Run|MPos:-261.104,-321.610,-10.000,0.000,0.000|Bf:11,254|FS:1986,200|Pn:AB|WCO:-200.000,-300.000,-80.300,0.000,0.000>
<Run|MPos:-261.117,-321.947,-10.000,0.000,0.000|Bf:11,254|FS:2012,200|Pn:AB|Ov:100,100,100|A:CF>
<Run|MPos:-261.129,-322.147,-10.000,0.000,0.000|Bf:12,254|FS:2012,200|Pn:AB>
<Run|MPos:-261.129,-322.259,-10.000,0.000,0.000|Bf:12,254|FS:1624,200|Pn:AB>
<Run|MPos:-261.154,-322.321,-10.000,0.000,0.000|Bf:13,254|FS:1624,200|Pn:AB>
<Run|MPos:-261.241,-322.321,-10.000,0.000,0.000|Bf:13,254|FS:1079,200|Pn:AB>
<Run|MPos:-261.365,-322.309,-10.000,0.000,0.000|Bf:14,254|FS:1079,200|Pn:AB>
<Run|MPos:-261.551,-322.284,-10.000,0.000,0.000|Bf:14,254|FS:0,200|Pn:AB>
stops here, can then home, jog, etc.
