fokoos stutter/grind
I was recently gifted a used Fokoos FE 20 laser. Never owned nor used one in the past. Using Lightburn software, it worked great for a few months on small miscellaneous projects. I first noticed the issue when I would find the project stopped mid run. And then trying to re-home, it would go in the opposite direction and then would stutter/glitch. This began happening every time I tried to frame and or run. Belts have been adjusted and cleaned properly. USB to USB-B cord has been replaced. As someone extremely new to this, I’m so lost as to what to do next. Any help is appreciated. Thank you
Make sure all set screws in couplers and motor pullies are tight first off.
