Going back to a discussion where the burn would stop before cut was finished.
The cure for me was to reduce laser power by 15% and do a double run. Had no problem since and it’s cutting ang engraving perfect.
Just thought I would put that out there.
Glad you solved it. However, your solution suggests either the laser or power supply was overheating. You might keep that in mind when you so your maintenance check.
