Font sizing oddity - saving from Illustrator to Lightburn
really odd one here…
if i create text in illustrator, then save as SVG, the sizing (when imported to lightburn) is WAY off… so a letter, say 3" wide in Illustrator, is actually ~ 2.25" wide when imported…
any ideas?
This ONLY happens if you create an SVG file, but NOT when importing a .ai file…
yes, the easy solution is to only do .ai. but I also have other CAD software, which exports .SVG, and this is impacting sizings…
Have you tried changing the SVG import settings in ‘Settings>File settings’ from 72dpi to 96dpi ?
ah, thx… that was set to 96dpi… i’ll re-check it when I can…
