Frame and cut job.go to repeat and framing goes elsewhere
Have new laser cutter engraver which is awesome,however when i have a job done and move to do the next job the framing does not do as i ask.I have had the same thing happen when i have just asked it to repeat the same job changing nothing.Now i am a quick learner and have had complicated programs for other things/hobbies but light burn does not seem to be particularly intuative and have spent a very long time trying to locate information as simple as how to reset windows when they vanish.I do not understand that i can complete a job and then ask it to repeat it and the framing goes somewhere else..(seems to be the previous job frame)the same happens when i start a new job it rembers the old framing even though it is not dissplayed.what am i missing,and why is this able to happen?
My first guess, since you don’t show us anything to go off of (screenshot of your Lightburn screen), is that you are using current position as your start from position. The first job starts correctly, but when it finishes the laser does not return to the start position from that job, so when you try to do it again it is starting from the new current position.
More info of your process would be helpful.
