When I click on the frame button in lightburn, my laser doesn’t move. Can someone help?
Mac computer with an Ortur 2.
Hi, you have to select the project first then frame.
I can click anywhere on the object and the laser will move there.
It had something to do with the image I guess. It was 14.7573 by 14.7573. I tried a different file and it worked.
Maybe you can answer another ? Everyday I hook my computer to the laser it says disconnected.
I restart lightburn and still disconnected.
I had to remove the laser and reinstall it.
Hi again, you should always start your laser and allow to ‘home’ before opening lightburn.
If you open lightburn first for some reason it doesn’t connect, you get in the habit after a few times…
