Frame does not work
The frame button in lightburn does not work correctly it moved to the far right or to the far left and then re-centers and does not come back to origin it’s really weird
In the “Start from” section, select the current positionand then match the zero coordinates of the design with the zero coordinates of the workspace (home), then use the frame button and see the result.
I have my tile in position, I have my Layer Line 1 parameters already set, I have my Job Origin set in the middle and the Start From set at “Current Position”. I then clicked on the “Set Laser position button” and it works fine, I click in the middle on my square or created object. The laser head finds the center just fine. But, when I choose the Frame option it completes the frame but it is about an inch off center to the top.
You may have a small “invisible” shape outside of your subject that you want to engrave. Under the edit menu, there is the function “select all shapes in current cut layer” which can help you find objects that do not belong to your design.
Sorry, I appreciate your feedback but I have difficulty sometimes understanding. Can you simply your explanation. Maybe give me step by step info on what you do. Even possibly email me screenshots on your settings to make sure mine are correct. Thanks so much. ddietsch@mac.com
