How can I get my framing light to work every time. Sometimes it works without changing any thing and I go back to make sure everything is good the light does not work.
Please give me directions to correct my problem.
I could not tell you why it works sometimes and not others - that sounds like maybe your device configuration is being changed by something outside of LightBurn, or you don’t have the fire power set quite high enough.
The actual instructions are here: How do I turn on my diode at low power to focus it or frame a job?
Check to make sure you have done all of this first.
