I did the update this morning and now the frame feature does not work.
I can run the laser and the file works but the frame will not work. I’ve restarted the laser and the computer.
I’m running the rotary if that matters.
Any thoughts?
Any thoughts?
This is found and fixed already, and we’ll be releasing an update shortly.
A number of people complained that if you pressed ‘Frame’ multiple times it would start framing again while the old one was still going and lose position.
The new update has code to check if the machine is already framing and to not do it again, but some controllers report “busy” differently, and so the check needed to change.
