Can someone please answer my question? I am having trouble framing… I have put a square box with my initials in it on lightburn.( simple first job, just for experience) after previewing, I go to frame. Once I tap frame the laser goes to the home position. I had to manually move the laser in the console, can someone please advise me on mobility of my laser and why does it go home when instructed to frame? Thanks in advance for any help…
Make sure you’re selecting the correct 'Start From’ position for what you’re looking to do. If you’re using Absolute Coordinates mode, make sure your laser is properly homed. If your laser does not have limit switches, you’ll need to manually home it by moving the laser head to the bottom left corner with the laser off.
Here are a couple of resources to help you get familiar with the way the ‘Start From’ setting works:
