Laser head will not go around the frame setting and just heads along y axis and crashes into the stop. Also dose the same when pressing the start button. Will home correctly and the nudge buttons also work. Any help appreciated thank you.
When you home the machine, if you then click ‘Get Position’ (in the Move window) what does it say? And where is the laser head when you do this?
Thank you so much for replying to my problem however I did manage to solve it by unchecking the ‘enable rotary’ button in ‘rotary settings’. I had this problem for three days and was getting desperate. Thank you again for your prompt reply.
That would do it.
