Frame works with out of bound art on Tool layer
If I have artwork that is too large (eg many pieces), I mark the ones I want to cut with a cut layer and those I will cut later with the Tool layer. This works well so I don’t have to delete any pieces and make separate files. HOWEVER, if I use the Frame tool, it thinks the Tool layer is in bounds and causes the steppers to go bonkers trying to reach the end. Probably taking some cogs out of the belts too. What should happen is Frame should only work for layers that will cut or engrave, in other words, NOT for a Tool layer.
You have the option to turn framing for Tool Layers off. :slight_smile:
