Connect, machine jogs to a zero zero Home position, no problems. Draw a test square in Lightburn, pin/snap the corner of the square to the X&Y zero. I’m in Absolute Coordinates, select Frame. Frames right on the money and returns to a position approx 1- 2mm away from the first Home position, in the Y axis. Position is reading zero/zero.
Click frame and it starts from this new position and ends approx 1-2mm up the Y axis, position says zero/zero.
So, I selected my Line and burned squares 7 or 8 times in a row. OMG what is happening to me. The burn is shifting over and over up the Y axis. After about 7 or 8 times is stops drifting and burns in the same spot. Get Positions still reads zero, zero.
