Framing Disconnected
Everything was working fine in Lightburn then my laptop died (battery doesn’t charge, plugged in all the time). I guess my power cable came a little loose and it died.
Once I got the laptop back up and opened Lightburn and my design, it won’t frame. Just keeps flashing ‘Disconnected’. I closed LB and restarted it again but no help.
What happened?
Thank you.
Did you select the right port?
Turn off your laser. Disconnect the power cabled and the USB cable for 30 seconds minimum. Restart your computer. After the computer restarts, plug in the power to your laser then plug in the USB cable to the computer. You should hear the “connected sound”. Now restart Lightburn and if not connected select the correct com port from the drop down menu in the laser panel.
I’ll give it a try. Thank you.
That worked. Thanks, again.
