Framing incorrectly
My machine isnt framing properly Im Getting error message
Alarm 3. Reset while in motion. Grbl cannot guarantee position. Lost steps are likely. Re-homing is highly recommended.
I’m totally new to this and have no idea what this means. Please help!
What machine do you have?
Sculpfun using lightburn and trying to install Cam 500 but it stopped framing correctly
You are trying to use two different software with 2 different coordinate systems I believe. You will need some more knowledgeable to get you set up to use both.
Misunderstood, thought you were trying to do both lasering and cnc routing. My machine does both and CAM means something different to me.
So, the problem is setting up the camera? Or is the issue not related to the camera? Which Sculpfun model do you own?
If it’s the camera, check here:
