Framing issues with my longer 10 watt laser
Charles
the green dot will not move to the corners in the file i’ve selected using user origin. when i hit frame the head keeps hitting the rails. the dot just stays in the lower corner of the workspace. it won’t move to the selected starting points of file i’m trying to frame.
Try using Absolute Coords. Either Home the machine if you have limit switches or power it up with the laser module in the front left corner. This will allow you to easily correlate the drawing position with the laser position.
There is a red cross (plus) that indicates Show Last Position, but the green and red squares do not normally move.
Use Cut Selected Graphics AND Use Selection Origin switches in the Laser window.
i don’t have limit swithes, it’s been working properly it just started doing it when i was in the midle of working on a file. let me try some of your suggesting
Tim is a put-it-here and go guy. I am an always-start-here guy. Pick which ever works for you.
turning on the selection origin fixed the problem, i don’t know how or when i turned it off.
thank you guys so very much,
Charles
