I have a 30 w fiber laser.
I have had 2 images where this has happened.
I trace the image and choose to fill. When I then frame the image, I will get and extra line and on one a triangle.
The line was from 12 to 3 (face of a clock) across the circle.
The other was a right triangle where one of the points went past the circle.
Is there an issue with the image?
jkwilborn
(Jack Wilborn)
2
Can you post a photo or screenshot?
This is hard to describe with just language.
Of the framing circle itself? (red laser)
jkwilborn
(Jack Wilborn)
4
Any information you can think of we might need is a good idea and prevents multiple posts just to get the basic facts we might need.
Where are the extra lines noticed? Preview, on the work or both?
If you don’t mind the .lbrn2 file for other questions I haven’t figured out if I need or not.
JimNM
(James )
5
Where does the source image come from? A pre-made image, import from Imagr?
1st guess is to UNGROUP the traced image. Select the offending scap lines and send them to DELETE-ville.
GROUP the object again, and live happily ever after.
system
(system)
Closed
6
