I am running into an issue when running camera lens calibration. When it goes to frame it is framing a significantly larger work space. The calibration says to use a sheet a paper but the laser is framing a 12 x 12 work area. What setting am I missing?
I have a reality Falcon 10w and a Mintion camera.
The size of the target marker engraving is determined by the Scale value in the Camera Alignment Wizard.
For best results, we recommend increasing that value so that the engraving is the largest possible size that can be engraved within your machine’s workspace, and use a piece of material larger enough to accommodate the engraving.
However, it is also possible to reduce the Scale to fit it to a smaller area like a sheet of paper.
