How do I get the full view of my honeycomb grid? I did the calibration and work but I only see about 85% of the grid.
The lens angle is too narrow. The only solution with that camera is to move it higher.
Can you adjust the camera angle to view where you do most of your work?
It’s built in an enclosure so I can’t go any higher. When I calibrate it can see the full view.
Then your lens calibration and (or) workplace alignment is not correctly performed.
If your entire honeycomb is visible in the preview window, then it should also be visible in the main window completely.
Ok, I’ll start over.thanks.
