Funzioni booleane
buongiorno,ho bisogno di aiuto,ho acquistato la licenza ma ancora non si attivano le funzioni booleane,nemmeno in strumenti, come posso fare? grazie mille
Certain conditions must be met before the Boolean tools can be used:
There are a few important things to keep in mind when using the Boolean tools and Weld:
** All selected shapes must be closed shapes, meaning they are complete, continuous loops whose start and end points are the same. If there are open shapes in your selection, the tools will be grayed out and unavailable.*
** The Boolean tools work with vector objects only. If there are any images in your selection, the tools will be grayed out and unavailable.*
** To use any of the Boolean tools, you must have exactly two shapes, two Groups of shapes, or one shape and one Group selected. If you have more than two shapes or Groups selected, the Boolean tools will be grayed out and unavailable.*
** You can use Weld to combine more than two shapes at once.*
** Grouping multiple shapes together tells MillMage to treat them as a single shape. For example, Group an outer circle with an inner circle to treat it as a donut shape rather than two separate circles. Grouping shapes in this way can sometimes yield different results than you’ll see with the same objects when they’re not Grouped.*
If your file meets these condition and still doesn’t work please post your file here for us to take a look at
Grazie mille,ho provato a creare un file nuovo con cerchi,ed effettivamente era quello il problema, ancora tante grazie :+1::+1::+1:
